Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Which 1600rpm 8kg washer? Siemens, Panasonic or… ?
- This topic has 7 replies, 5 voices, and was last updated 15 years, 5 months ago by
kunid.
October 13, 2010 at 8:57 pm #57963
kunid
ParticipantConsidering the following washing machines, they all feature 1600rpm spin, 8kg load, AAA energy efficiency and 5 year warranty.
Panasonic NA-168VG2 – 489 pounds delivered
Siemens WM16S383GB – 532 pounds delivered
Unsure which to go for, would really appreciate your thoughts!
October 13, 2010 at 9:01 pm #332812whirlpool
ParticipantRe: Which 1600rpm 8kg washer? Siemens, Panasonic or… ?
hi i think i would buy a hotpoint aquaries comes with the same warrenty but its alot quietier
October 13, 2010 at 9:14 pm #332813CJAPeterborough
imho go for the Siemens-the build quality is probably next best to Miele
and if you keep it for ten years there will be plenty of folk and parts available to fix and service it.
Panasonic is a great brand name but I never even seen one of their washing machines
-thin on the ground=harder for parts and service.Looks a nice piece of kit brushless motor etc but are you a risk taker?!
October 13, 2010 at 9:19 pm #332814odom
whirlpool wrote:hi i think i would buy a hotpoint aquaries comes with the same warrenty but its alot quietier
😆 Yep, great choice if you need a really heavy paperweight to use in a couple of years time when the module blows up or the drum weights disintegrate.
Out of the two you’ve given I’d go for the Siemens, because there simply aren’t enough Panny’s around for us to get a good idea on long-term reliability. BUT really I wouldn’t spend my money on the Siemens anyway. This is simply because as engineers we know that you can’t shove an 8kg drum onto domestic suspension with concrete counterweights and expect something that will last.
Really if I were you I’d either save myself some money and get a 6kg German Bosch that should last 8-9 years, or if you’re doing enough washing to make the 8kg drum worthwhile, splash out and invest in an ISE, which can do 8kg loads and will last you 20 years.
October 13, 2010 at 9:30 pm #332815kunid
odom wrote:
whirlpool wrote:
hi i think i would buy a hotpoint aquaries comes with the same warrenty but its alot quietier😆 Yep, great choice if you need a really heavy paperweight to use in a couple of years time when the module blows up or the drum weights disintegrate.
How can you tell whether it’s a German Bosch as opposed to a Spanish built one?
October 14, 2010 at 12:08 am #332816kunid
Interesting read regarding the drum size.
But it seems all the Siemens machines are 7kg + and Bosch’s higher end machines (which may be built in Germany) are also 7kg +.
I’ve got a budget of around 500 (preferably under!), which 6-7kg machine would you recommend?
October 14, 2010 at 12:37 am #332817kunid
Some other options…
Bosch WAE28469GB – Exxcel 7kg, 1400rpm, AAB, 2 year warranty – 362.99 (but is this a Spanish machine?)
Siemens WM14E162GB – 7kg, 1400rpm, AAB, 5 year warranty – 399.99 (once again are Siemens budget machines even made in Germany?)
There’s also a 7kg 1400rpm Panasonic with 4 year warranty for 368, but as mentioned above they’re a bit too new on the block.
Heh, no idea which direction to go! The ISE machines (or a Miele 6kg) look great, but can’t afford those.
October 14, 2010 at 7:43 am #332818don
ModeratorRe: Which 1600rpm 8kg washer? Siemens, Panasonic or… ?
The Bosch machines with the half moon shaped door handle are normally built in Bosch factories around the EU. The WAA series with the small square door handle and lower spec are normally made in Spain.
A very similar thread to this one only last week where the OP had very similar criteria here ended up with a good result.
HTH 🙂
Don
