Re: Which Bosch stacking kit ?
Don,
Thanks for the advice. The dryer currently sits on top of the washer with no problem, so the dimensions are not far apart. And they are both situated against 2 walls in a corner. There is only the risk that a ‘wild’ spin cycle would shake things up! Hence the search for a stacking kit to reduce the risk.
Are you saying that you think the WTZ1120 won’t fit the new shape washing machine? But that it should fit the dryer. Do I understand you correctly?
Steve
