Which compressor
  • #43961
    geoff1
    I am trying to identify a compressor for a Maytag G32026PELB unit.
    It is a 2 door fridge (400 ltrs) with a slide out freezer draw (150 ltrs)
    numbers on the compressor fitted make no sense and Maytag what the earth for one.
    Would a 1/4hp do for this type of unit like the Zem GL90AA, Aspera NB1118Z & Embraco ECS70HLP ?? compressor fitted is a R134 with cap start.
    Advice on what to fit would be appricated
    Geoff
    #279235
    BobHope
    Re: Which compressor
    Hi geoff1,
    a 1/4 hp compressor will work ok but you will have to modify the pipework and wiring and also check the working voltage as some maytags are 110 volt with a dropping transformer.
    Bob.
    #279236
    geoff1
    Cheers Bob
    Will need to check about a transformer
    Geoff
    #279237
    BobHope
    just check the compressor rating plate the voltage will be on there
    bob
