Which Integrated Washer/Dryer
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Which Integrated Washer/Dryer
  • #57968
    dmajohnson
    Hi There
    Before I get bombarded with “Washer Dryers are c**p”, I have no choice. My kitchen is the size of a postage stamp and I need both facilities in one appliance.
    My old Zanussi ZJD-1219 has broken down yet again and I’ve had enough.
    To make it even more tricky I need the applicance to fit within the same area as the old one which is:
    Height – 82 cm (32.3”)
    Width – 60 cm (23.6”)
    Depth – 54 cm (21.2”)
    Any advice is very much appreciated.
    #332828
    don
    Re: Which Integrated Washer/Dryer
    The narrowest I can find is the Zanussi ZKI225 which is quoted at 555mm deep. Most come in between 575 and 585mm deep, it may be an idea to remove the old machine and have a measure if you would like to have more choice.
    HTH 🙂
    Don
    #332829
    dmajohnson
    Found this.
    http://www.johnlewis.com/Shopping/Produ … =230473548
    I was thinking of taking the 5 year warranty for the extra £75 squid.
    #332830
    don
    John Lewis washer dryers are usually made by Zanussi and with the extra warranty it should be a safe bet.
    Don
    #332831
    dmajohnson
    Haha pity that that is only a washer.
    What an idiot I am.
    Just cancelled the washer for a refund.
    Total pain in the arse to cancel the extended warranty though, I have to ring a premium rate number who then tell me it’s not on their system and to ring back another time. Shame on you John Lewis.
    #332832
    don
    dmajohnson wrote:Gah, can’t edit posts on this forum.
    I’m looking at a Zanussi now.
    ZKI225 vs ZKI445
    I noticed the ZKI445 uses that Jetsystem thing. I think I read somewhere to avoid that as it screws up. Is this true?
    No worries, moved your post across 🙂
    Set the comparison on those machines for you on the Zanussi website.
    As for the jetsystem thingy I`m sure someone will be able to respond.
    HTH 🙂
    Don
    #332833
    kladave
    Your term ‘screws up’ what’s that supposed to mean??
    Jet system machines have an extra pump to spray water onto the clothes and like any other pump it may fail in years to come.
    HTH
