Which LG washer to avoid?
Home Forums General Trade Forum Which LG washer to avoid?
Viewing 15 posts - 1 through 15 (of 20 total)
  • #79330
    twicknix
    My wife is huge fan of LG. Our current one (7.5kg) is approaching ten years old. No faults at the moment other than worn circulation pump which I will replace when I get the chance.
    Once you tried LG for its quietness, you can’t go back to motor and belt driven machine.
    ‘Er indoors was browsing the trade sites and found one to her liking. The 9kg model and the 1400 spin. Our current one is 1200 spin.
    I seem to recall that a certain LG rep at the WTA conference last year told me to avoid a particular sized drum. I can’t remember if it was the 9kg or the 11kg.
    Please confirm and which model is best? Or should we plump for the Samsung instead?
    #408840
    Re: Which LG washer to avoid?
    Just replace the Askol pump..bog standard one.. If you want a complete tank,bearing ect unit for it Im sure theres on on the top shelving still in its box 🙂 .
    Put your misses in her place..then dive for cover.
    Avoid anything bigger and faster..they wear out faster and break down
    Bryan
    #408841
    twicknix
    The bearings were replaced 4 years ago, the following year complete set of shocks and springs, new door seal, the year after new dispenser jets.
    It appears to be needing attention on yearly basis. Don’t get me wrong, I do love our current one.
    Sometimes if you wanted a fresh look to the kitchen and for her sake she likes modern appliance. To be fair our current one is 10 years old and outlasted most of my customers Bosch washer.
    #408842
    …… All of them!
    Invest in Miele (dogs dagglies) best 900 quid you’ll ever spend. Samsung/LG oriental landfillers.
    #408843
    Or better still the ISE
    Bryan
    #408844
    stratfordgirl
    From reports I’ve had from customers, the big drum cantelevered suspension models frequently give trouble spinning. If I recall correctly, they incorporate self-adjusting mobile counterbalance balls built into the front rim of the drum. As far as I know this design is used on the 10, 11 and 12 kg models.
    I’ve observed the pumps fitted to current LG models and supplied as replacements are poor Chinese quality, so only seem to last a couple of years in family use. Apart from that, they are pretty nice machines!
    #408845
    twicknix
    stratfordgirl wrote:From reports I’ve had from customers, the big drum cantelevered suspension models frequently give trouble spinning. If I recall correctly, they incorporate self-adjusting mobile counterbalance balls built into the front rim of the drum. As far as I know this design is used on the 10, 11 and 12 kg models.
    Thank you, it’s nice to have someone that answers the questions correctly rather than slagging it off.
    I do not have £900 to spare to buy those Miele or ISE. The machine in question is on special offer that caught my wife’s eye. I realised this model is the steam version (9kg version). I do not know much about it and then there is this Samsung model the Ecobubble (8kg). From my observation both makes are very similar and uses same technology such the direct drive motor.
    I’m leaning toward the Samsung. I know it is slight change of subject, does anyone have any thoughts on it?
    #408846
    twicknix wrote:I’m leaning toward the Samsung.
    Don’t lean too far because a Samsung is very unsupportive. Can’t afford a Miele yet want a quality silent drive machine? Then your next thought should be the quality of Siemens. 😀
    #408847
    twicknix
    It was decided that I shall keep on repairing the current LG until spares becomes obsolete.
    #408848
    trotter
    LG are a million miles better than many other brands available at the moment, as for Miele well yes ….Until you look at the cost of spare parts! If you know what you are doing with LG then they are simple to repair and the cost of parts are far below most others. The direct drive motor is one you will not find on any other UK sold washing machine.
    #408849
    trotter
    incidentally R600a the ISE is useless without support!
    #408850
    Lawrence
    trotter wrote: The direct drive motor is one you will not find on any other UK sold washing machine.
    Apart from the Samsung …
    #408851
    Pretty much all my staff have now got LG machines usually a 8kg 1200rpm,which is our best selling LG, and they are all happy, however I have the 11kg and its rubbish, unless the load is perfect it just wont spin,
    #408852
    twicknix
    trotter wrote:LG are a million miles better than many other brands available at the moment, as for Miele well yes ….Until you look at the cost of spare parts! If you know what you are doing with LG then they are simple to repair and the cost of parts are far below most others. The direct drive motor is one you will not find on any other UK sold washing machine.
    The direct drive is one of the many reasons why my wife and I opted for the LG. It’s simple in design but so effective. I like working on LG as they are the most enjoyable machine to work on. The most common problems I found with LG are worn shocks and worn bearings that are often too late to save the machine (but that usually the case if the owner installed the machine in the garage or far flung corner of the house where you can’t hear it otherwise the machine would have been saved).
    I have managed to rescue our current LG, now it is fitted with new pumps. I hadn’t realised how noisy the old pumps were until the new one were fitted.
    I have not yet worked on a steam version but I would expect it to be simple in design. Perhaps more problematic in hard water area?
    The Samsung are showing confident on their washing machine by offering 5 years guarantee. It won’t be long that LG will follow suit.
    #408853
    twicknix
    Gentleman, please note that ‘er indoors reads these posts! Lets be nice about us women.
    Love
    ‘Er indoors aka unpaid secretary
