Re: Which way does the cold water pipe go
iadom wrote:The angled connector should go on the back of the machine, this allows the pipe to drop down from the back without being bent at right angles when the machine is pushed back.
I pulled the old machine out and I can see that you’re right about the angled connector should go on the back of the machine. The way the council put the pipe on it put’s pressure on the connector on the back of the machine when it’s pushed back.
