While I’m at it … servicing ?
Home Forums Public Support Forums Help And Support Cooker And Oven Forum While I’m at it … servicing ?
  • #17004
    Mark_h
    Hi, I’m planning to change the fan heating element on a Candy F241 cooker. While I’ve got it in pieces, are there any parts that need any servicing – eg some WD40 on the Fan / Cable connections – not sure if this will help or harm….
    tia
    #172506
    Re: While I’m at it … servicing ?
    Try not to use wd40 anywhere near the fan motor, the bearings are of phospher bronze and therefore are self lubricating. WD40 will harm the bearing
    Usually a vacumm cleaner will be required for an old appliance along with a degreaser, you’ll see why when you do the job.
    Power off at the mains and remove the fuse or set the trip to OFF before starting any maintenance.
    hope this helps
    Kevin
    #172507
    Mark_h
    Cheers Kevin. Info appreciated.
