Whilrlpool ADP 2315 Fault query
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Whilrlpool ADP 2315 Fault query
  • #74844
    Mrs Arcanum
    I have a Whilrlpool ADP 2315 with the 6 flashing lights error code.
    The hose is NOT kinked.
    The water tap is NOT closed
    Water pressure is fine.
    Filters are clean.
    Drain hose is not kinked.
    No foam inside.
    It drains perfectly well, so I am assuming there is nothing wrong with the pump. I have checked behind the bottom panel where the pump is and the area is dry.
    Any clue as to the fault would be brilliant.
    #393082
    deltra
    Re: Whilrlpool ADP 2315 Fault query
    Flow meter!
