Hi All, Please can someone help me before I pull out what little hair I have left. My whirlpool washer had a clean pump light come on mid cycle, so I read the instruction manual and it said press reset which I did. That was all ok then the next time I tried to wash something the clean pump and service light came on.So I stripped all the pipework from the pump to drain which was all blocked up and then I ran the machine again, same problem service light came on but now the machine won’t spin either. Anybody any ideas where I should try next? Thanks if you can help.
