whirlepool dishwasher adg 6340 1x
Home Forums Public Support Forums Help And Support Dishwasher Help Forum whirlepool dishwasher adg 6340 1x
  • #29209
    dado
    machine over filling but does not have a pressure switch what controls the water level
    #222312
    smartin
    Re: whirlepool dishwasher adg 6340 1x
    hi dado for anyone to be able to help we will need a little bit more to go on like make ,model and serial numbers smartin
    #222313
    It’s a Whirlpool ADG6340IX………..
    Water level is controlled by a diaphragm switch in the sump under the filters.
    Penguin45 wrote:Look into the sump under the filters and find the black mesh cover at the three o’clock position. That is the level switch and has a bad habit of filling up with fatty deposits until it gets jammed in the full position. Hot water and a toothbrush may clear it – often it will need to be removed for better access. It’s a twist fit from underneath.
    Power off, of course.
