whirlpool
  • #50161
    waters
    Fridge freezer ARC7610
    Runs normal but when it switches off the only way to get it to come back on, is switch the fridge sensor off {stat} in the fridge and back on again and it starts up .
    This just looks like a small a potentiometer behind the dial.There is a space 4 sensor on the side and on the back there is another long this white sensor. This has 2 wires to it and it goes through the back of the fridge and can see no way to replace this .
    Anyone seen these and which do i replace.
    #303804
    MKR
    Same problem as above…. is it likely to be the PCB or something else?
    #303805
    MKR
    For future reference – PCB fitted, and fault repaired.
