Home › Forums › Public Support Forums › Spare Parts Help › Whirlpool 183 door handle replacement
- This topic has 8 replies, 2 voices, and was last updated 18 years ago by
Idiot.
April 2, 2008 at 9:38 pm #35722
Idiot
ParticipantThe user name says it all really…
Washing machine is a Whirlpool 183, more than 10 years old but still works fine. The handle snapped, bought a new one BUT someone else tried to replace it, failed and left so I can’t see how to assemble/replace. Could someone point me to a diagram please? Handle looks like this
http://www.4washerhelp.co.uk/cgi-bin/product.pl?PID=133824&brand=Whirlpool&model=183&part=door{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d}20handle
Mainly the metal clip I can’t place.HUGE thanks in advance…
April 2, 2008 at 11:27 pm #247760Penguin45
ParticipantRe: Whirlpool 183 door handle replacement
Easy bit – flat bit with the triangle pushes up the inside of the handle. Twiddle the spring to fit between the pegs on the revers side. Push it through the door, fit pin and latch hook from the other side. Then, fit the spring with the retaining screws so that it pushes the hook towards the outer edge of the door. Easy peasy.
April 4, 2008 at 11:21 am #247761Idiot
Penguin, THANK YOU!!!!
Will try that tonight. Sorry for late response, been tied in meetings, but really, really appreciate your help.
Will let you know if I can do it…
April 5, 2008 at 2:51 pm #247762Idiot
Tried, tried again, kept trying, failed…
The coiled spring, plastic handle and clear plastic triangle are fitted together. But when I put it through the door, I can get no further. I assume the clip goes on the bar through the holes in the middle of the triangle, but does it clip into the machine to the left or right? And where on earth does the other spring go? Can see where the screws go but just can’t figure where the coils/flat parts fit. And am going mad.
April 5, 2008 at 7:03 pm #247763Penguin45
The two flat loops of the spring screw to the door. Arrange it so that the two side loops are inside the body of the door and the cross piece lies like a ramp against the door hook.
April 5, 2008 at 8:20 pm #247764Idiot
Thanks again for taking the time to reply, Penguin. What you describe is (I think!) what I’ve been trying; is it normal that I have to really force the spring to match the screw holes? I think I had it right once but it was clicking badly so I (foolishly) tried again and have failed ever since. Hook does go in the middle of the triangle with hook part facing the outside of the door, right?
God I feel useless. At this rate I’ll take all the thread out of the holes and have to buy a whole new machine, which needless to say I can’t afford right now.April 5, 2008 at 8:23 pm #247765Penguin45
Correct! The spring must be under tension, otherwise it won’t push the hook across to work the door lock.
April 5, 2008 at 8:26 pm #247766Idiot
OK, will keep trying…! Thanks again.
April 5, 2008 at 9:41 pm #247767Idiot
OK, following Penguin The Expert I tried; problem is that indeed the screws wouldn’t catch so I must have destroyed the threads inside. Tried my Dad’s old trick with a bit of broken matchstick (failed again, story of my week) but then swapped the screws with the two holding the plate where the hook goes into the machine itself. While not as solid as it clearly should be it seemed to work, so will try the machine tomorrow and see… with stuff that doesn’t matter if it gets stuck inside until I have to call someone…
Thanks Penguin, thanks a thousand times over!
