Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › whirlpool 20 rbd 4a+pt no ice
- This topic has 14 replies, 2 voices, and was last updated 14 years, 9 months ago by
slyp98.
July 10, 2011 at 7:34 pm #63854
slyp98
Participanthi guys i went to this f/f and its not making ice customer sayes he left a bottle of champers in there and it popped and gushed everywhere , anywho the actual dispenser motor is fine , but i checked continuity on the top motor and nothing even when i bridged out stat not working , so a new motor and timer unit needed but prob is i cant find em anywhere , also when i checked supply voltage to motor its only reading 190v ? anyone have info on these thanks
July 11, 2011 at 7:56 pm #355211slyp98
ParticipantRe: whirlpool 20 rbd 4a+pt no ice
hello hello hello is there anybody out there ? just nod if you can hear me .. is there anyone home ? so i removed icee makeree and checked it manually with flying lead and hey it works, mould heater ok , motor spinning round , fingers moving with motor , now the water is dispensing from the flap in door , but no water dropping into the mould , are the 2 linked by one valve or are there 2 seperate ones thanks
July 12, 2011 at 6:01 am #355212daisbiz
hi there is a two way vavle in the back one pipe goes to the water dispenser and other to the ice maker maybe blocked.disconnect and blow up it.
July 12, 2011 at 8:44 am #355213slyp98
cheers
July 17, 2011 at 8:25 pm #355214slyp98
seems to be clear at the pipe , anyone have info on the infra red emmitter and reciever setup thanks
July 19, 2011 at 5:37 pm #355215slyp98
commercial code 858642015000 cheers
July 26, 2011 at 6:29 pm #355216slyp98
anyone ?? i have no lights on infra red emmiter
July 27, 2011 at 5:24 am #355217daisbiz
how old is machine,some u can self test,the serial number gives the age.sounds like the backboard tbh.
July 27, 2011 at 8:25 am #355218slyp98
i dont know age of m/c s/n is 110802 001987 , i have an earlier tech sheet for the sbs models which sayes fix the emmiter flap in the closed pos. close the door switch ice maker on , within 60 sec. openn the door , hold light sw in closed pos. switch ice maker on , and listen to reciver led output code , i tried this it did not work , if i had tech sheet i would be able to figure it but it seems hard to get info on the whirlpool stuff !!
July 28, 2011 at 6:08 am #355219daisbiz
1108 so its 11 week of 2008,anyway turn ff off for about 2 minutes,turn ff back on open “freezer” door and activate the freezer light switch 4 times this will send ff into selftest,on freezer side numbers will shown up as 07-06-05-04-03-02 is a 2 minute test all the rest are a couple of seconds the if the display comes up as 00-0 the mechanics are ok,if u dont go into selftest 1st time try again ie turn off 2 minutes,to exit self test activate freezer light switch 4 times again or after a couple of hours it resets itself.ff will go back to factory settings ie -18 and 5,this will test the icemaker side.hope this helps.
July 28, 2011 at 8:32 am #355220slyp98
thanks , is there a number displayed to indicate the fault ?
July 28, 2011 at 3:11 pm #355221slyp98
test worked for me did go through 07 to 02 and then kept flashing alternating between 02 and 00 for about a minute and then went on to 01 and 00 for another minute or two before i ended the test . what does this tell you ? thanks
July 28, 2011 at 7:27 pm #355222daisbiz
that the mechanics are ok and it sounds like a backboard 😐
July 28, 2011 at 8:39 pm #355223slyp98
thought as much cheers mate
September 12, 2011 at 9:59 pm #355224slyp98
replaced control module all working fine again thanks k
