Home › Forums › Public Support Forums › Help And Support › Cooker And Oven Forum › whirlpool 2000 model G2P61F/SS oven
- This topic has 10 replies, 2 voices, and was last updated 12 years, 12 months ago by
amanda66.
April 10, 2013 at 5:09 pm #74965
amanda66
Participanthi all turned on my oven it came on was on for around 5 mins then turned of and wont come back on. it also has a built in grill which also isnt working any ideas what is wrong. thank you.
April 10, 2013 at 5:18 pm #393426Specialist01269
ParticipantRe: whirlpool 2000 model G2P61F/SS oven
Hi: Do you know if there’s actually power going to the oven ?
April 10, 2013 at 5:25 pm #393427amanda66
well the hob is working fine but nothing else stupid question but how will i know if power working on oven or not?
April 10, 2013 at 5:28 pm #393428Specialist01269
If the hob is working then in theory you have power to the oven as well, if there’s a Digital display or an oven light then if you’ve got power to the oven they should be lit.
You may want to consider calling a local engineer to look at it for you.April 10, 2013 at 5:30 pm #393429amanda66
yes the hob is working doesnt have digital display. The oven or the grill wont work?
April 10, 2013 at 5:33 pm #393430Specialist01269
Is there a light inside the oven ?
April 10, 2013 at 5:34 pm #393431amanda66
no.
April 10, 2013 at 5:38 pm #393432Specialist01269
Ok: 1 thing you can do is check in the cupboard either side of the oven to check if the oven is connected via a plug or fused connection unit. If it is then check the fuse either by replacement or with a Multimeter to see if it’s good, if you don’t find the problem then i’m afraid it’s time for an Engineer. If you do need an engineer, take a look at the page above your 1st post & click on the link. You should be able to find an approved engineer in your area.
April 10, 2013 at 5:39 pm #393433amanda66
ok thank you
April 10, 2013 at 5:42 pm #393434Specialist01269
No problem, your welcome. Please let me know what you find.
AndyApril 10, 2013 at 5:43 pm #393435amanda66
will do think im gona call an engineer in the morning. thank you for your help.
