Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Whirlpool 3LSC8255EQ1
- This topic has 9 replies, 5 voices, and was last updated 16 years, 8 months ago by
Alanj.
July 22, 2009 at 1:05 pm #47267
Alanj
ParticipantHi Guys,
went to whirlpool american style top loader and found the cam/bearing on the agitator in pieces. How do you remove the agitator to gain access to the cam/bearing? No screws or nots visible. I assume the top of the agitator screws of somehow but because it’s plastic did not want to force it, and it looks quite aukward. 😳 ❓Alan
July 22, 2009 at 1:19 pm #292893electrofix
ModeratorRe: Whirlpool 3LSC8255EQ1
there is a cap inside the agitator (plastic about 2 inches across) got hold of it with pliers an pull gently
underneath there is a bolt approx 10mm i think remove and the whole thing comes offsimple these machines are great to work on when u get used to them
regards
July 22, 2009 at 1:24 pm #292894bzz67
ParticipantRe: Whirlpool 3LSC8255EQ1
theres a plastic piece with wings in the centre that will pull out then you will see the bolt head, you will probably work it out from there, when you have lifted the agitator out just take note on how the the clip and plastic bit comes out.[/code]
July 22, 2009 at 1:33 pm #292895EFS
The screw under the cap is 5/16″ best to use the right socket in case it is stiff.
The cam and ratchet dogs come as a kit 481952838376 8)Steve
July 22, 2009 at 9:23 pm #292896Alanj
I have lifted out detergent cap, and then clear plastic cover with wings which has a rubber o ring around it but no sign of a bolt head.
Alan
July 22, 2009 at 9:34 pm #292897roly16
It must be there. Is it covered in soap powder?
July 22, 2009 at 9:35 pm #292898EFS
The hex head screw is in the recess in the centre of the cam.
It may be hidden by debris unless someone has removed it in which case the agitator will pull straight off the centre post.Steve
July 22, 2009 at 10:28 pm #292899Alanj
I’ve sent roly16 & bzz67 a sketch of what I can see looking from above agitator for more info. Please check your e-mails
Alan
July 23, 2009 at 10:45 am #292900Alanj
Hi Guys,
thanks for all your help, I did find the bolt under soapy white water 😳 . Must have been one of those days 8O.Alan
July 23, 2009 at 11:35 am #292901bzz67
well done, i was starting to think it must be one i hadnt seen before.
