Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › WHIRLPOOL 3LSC8255EQ1
- This topic has 7 replies, 4 voices, and was last updated 16 years, 7 months ago by
Alanj.
August 17, 2009 at 2:03 pm #47856
Alanj
ParticipantHave to do a gearbox and clutch on this W/P Top loader. Have not done one before so any pointers would be great. Any seals that need replacing or do they come with gearbox 😕
Thanks Alan
August 17, 2009 at 3:58 pm #294813Bill
ParticipantRe: WHIRLPOOL 3LSC8255EQ1
Alan,
The staight answer is NO but why are you changing the clutch, is the brake working o/k.
Bill Ellis :scot:
August 19, 2009 at 12:49 pm #294814Alanj
Hi Bill,
read this posting and thought the fact that there was a fair bit of oil on floor under machine and around gearbox that both would require changing. ❓Alan
August 19, 2009 at 12:51 pm #294815Alanj
Sorry Bill link to posting is http://www.ukwhitegoods.co.uk/modules.p … 452#237452
Alan
August 19, 2009 at 1:02 pm #294816electrofix
ModeratorRe: WHIRLPOOL 3LSC8255EQ1
really simple to change this
if i am right you will need gearbox and spin clutch unit which is sat on top of box
as a quick guide
remove control panel screws slide forward and hinge it back
unplug wires to casing and remove clips holding casing in position tilt towards you and slide off
unclip pump, unplug motor , capacitor and earth wire remove clips and remove
take top off paddle in tub look down inside and remove plastic cover and remove bolt holding paddle. remove paddle under paddle there is somtimes a metal clip and washer remove
tilt machine at about 45 degree angle remove 3 bolts holding gearbox then lower box away
all you have to do is swop clutch and put back try not to turn tub if u do it will drop (not a lot ) and you will have to turn tub pushing up to be able to get box back in
Hope this helps
August 19, 2009 at 5:21 pm #294817EFS
No need to remove the cabinet
The machine loses rigidity if you do
Remove the agitator then tip machine backwards against the wall.
unclip pump and push to one side leaving hoses attached.
Disconnect all wiring to motor and unscrew three hex head screws (1/2″)
and pull gearbox out with motor attached.Steve
August 19, 2009 at 9:27 pm #294818Alanj
Thanks Steve, I thought it might be possible to do that. 😆
Alan
August 21, 2009 at 3:37 pm #294819electrofix
never thought of that twist will try next time i get one
