Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Whirlpool 3LSC8255EQ1 Top Loader Service Manual
- This topic has 7 replies, 2 voices, and was last updated 15 years, 4 months ago by
monkey.
November 14, 2010 at 7:45 pm #58841
monkey
ParticipantHi Guys
Does anyone have service manual for this machine. I seem to have a problem with the brake. When it starts to empty before the spin the brake does not keep the drum stationary so it spins with afull drum of water.Can any one help?November 14, 2010 at 8:05 pm #335842EFS
ParticipantRe: Whirlpool 3LSC8255EQ1 Top Loader Service Manual
monkey wrote:I seem to have a problem with the brake. When it starts to empty before the spin the brake does not keep the drum stationary so it spins with afull drum of water.Can any one help?
Its supposed to do that.
What is the reported fault?
Steve
November 14, 2010 at 9:20 pm #335843monkey
It is banging during the spin,I put this down to it spinning full of water, I called to another top loader and I watched it empty and it did not release the brake till it was empty of water.
November 15, 2010 at 12:47 am #335844EFS
monkey wrote:It is banging during the spin,I put this down to it spinning full of water, I called to another top loader and I watched it empty and it did not release the brake till it was empty of water.
Some machines have a neutral drain gearbox fitted which does what it says ie. drains in neutral.
Most UK models will start spinning full of water.Check for a broken suspension spring.
The one at the back which is connected from the tub mount down to the chassis is the likely culprit.Training manual here
Downloadable pdf.
Steve
November 15, 2010 at 10:16 pm #335845monkey
I have checked the springs,I have also replaced the gearbox in march because it agitating before the spin on distribution. If you any more ideas I grateful.
November 15, 2010 at 11:13 pm #335846EFS
The friction pads can wear out, break or get contaminated.
There are two sets of three (both different)Only other thing I can think of to check is the weight ring around the top rim of the wash drum.
It contains water which moves round during spin and helps to even out imbalance.
If the water has got out the balance will be affected.
Don’t know if it comes as a spare or if you need a complete drum.Steve
December 4, 2010 at 9:31 am #335847monkey
Hi Guys
I called again this time with the manual. When I the machine filled with water and started to agitate, I noticed that it is only going clockwise,is this normal or should it go back and forth. I did change the gearbox about 6 months ago,I also noticed that tthey did not seem any delay to allow the machine to empty of water before going into spin.December 11, 2010 at 12:59 pm #335848monkey
Hi guys
I could really do with your help on this one if someone could get back to me. -
