WHIRLPOOL 3LSC8255EQ1 TOPLOADER
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries WHIRLPOOL 3LSC8255EQ1 TOPLOADER
  • #9999
    mbdas
    Morning all,
    got a american T/L with no spin Ive removed cabinet and motor and can see a plastic part between the gearbox and drum which has broken I think this is the clutch am I correct if so what causes them to break is it a case of replacing this or do you have to buy a clutch and gearbox complete ❓ Ive not taken the gearbox out as its next to a toilet and it would mean lifting the machine over it, nice place to be laying on the floor 😥
    mark
    #137763
    Dave_Conway
    Re: WHIRLPOOL 3LSC8255EQ1 TOPLOADER
    Between the gearbox and drum or between the motor and gearbox ?
    The most common part to break is the drive coupling which is two rubber blocks, one on the motor, the other on the gearbox and the plastic part which locates in to both of them.
    Part number 481932528035 (nice piccie on Connections).
    #137764
    mbdas
    Sorry Dave its between the gearbox and drum if I shine my lamp on it I can just about see it I dont have a parts break down so cant tell you what its call but its not that part unfortunately
    mark
    #137765
    there are several parts involved here.
    Under the drum is a drive block, a drive tube and then the clutch mecanism……any could cause your problem.
    You will have to remove the the drum to find out.
    Kevin
    #137766
    Dave_Conway
    Emailing a piccie now 😀
    #137767
    Tubs
    Kevin
    Anyone know if there is a Big socket or spanner to fit the big “nut” that holds this on, or is a case of make do like I have been doing?
    Steve
    #137768
    mbdas
    Thanks for the pictures Dave your a star I’m going back tomorrow afternoon to strip it down Ive asked her to empty the room so I can get to it properly whats the bet that she doesn’t do it toilet infront of washer amercian dryer next to it then a d/w with loads of coates, towels, dirty washing o yes and a sink 🙄
    thanks again Mark
    #137769
    Dave_Conway
    No problem Mark..
    And Steve, I make do as well, there probably is one made by Whirlpool but it would cost more than the appliance I expect 😀
    #137770
    Tip, the whole gearbox, motor and shaft assembly can be slid out from underneath without even touching that nut on the top with the drum in situ. That will give you access to the clutch/brake thing.
