whirlpool 3lsc8255eq1 toploader no spin
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries whirlpool 3lsc8255eq1 toploader no spin
  • #34103
    monkey
    Hi Guys
    Can you help with problem it is very slow in picking up speed on the spin.Sometimes you have to keep the lid open and press the lid switch and spin the drum by hand to get it started. Do they have a clutch or is it the gear box.
    #241274
    spanner51
    Re: whirlpool 3lsc8255eq1 toploader no spin
    From the symptoms you describe, it sounds like the drive clutch slipping. Easy to replace p/n 481969018152
    #241275
    monkey
    can you give me some tips on how to replace the clutch or better still if you have a manual
    #241276
    Useful information in this thread.
    http://www.ukwhitegoods.co.uk/modules.p … ol&start=0
    #241277
    monkey
    I have read the thread but it does not tell me how to change the clutch.Can you give me any advice.
    #241278
    spanner51
    After removing the 2 clips from behind the facia, lift off the cabinet.
    remove agitator
    remove pump
    remove motor
    3 bolts and gearbox will slide out
    drive clutch is held on to top of gearbox by a spring clip
    assemble in reverse order, and have fun.
