WHIRLPOOL 3LSR6233EQ1 DRUM SEIZED.
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries WHIRLPOOL 3LSR6233EQ1 DRUM SEIZED.
  • #69269
    keithwilliams
    while repairing dishwasher i got asked about this problem. i have never worked on one of the but suspect that they are eay to do. thing is diagnosing the fault. basicall it will not spin. when i tried to turn the drum in either direction i could barely move it. i wondered if something was stuck under the agitator(is that likely) but i couldn’t get it off. any advice would be appreciated although im tempted to refer her to local whirlpool guy.
    #374189
    Hollytree_Technical
    Re: WHIRLPOOL 3LSR6233EQ1 DRUM SEIZED.
    Is it a Top Loader?
    Assuming that it is a top loader then the drum has an automatic brake on it.
    Does it agitate the central shaft during the wash cycle? if it does then it is probably the clutch and if it doesn’t then it will be the three piece coupling.
    Jem
    P.S. To remove the agitator you need to unclip the detergent dispenser off of it and look down the middle, there should be a plastic cap to remove which gives access to the bolt.
    #374190
    Firestarter
    There are some good videos on YouTube, search for “whirlpool clutch” or “whirlpool coupling”
    #374191
    keithwilliams
    it was the three piece coupling. thank you very much guys. its really appreciated. also very simple job.
    keith
