Whirlpool 3RGSC9400RL0 not spinning correctly
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Whirlpool 3RGSC9400RL0 not spinning correctly
  • #60927
    odom
    Was called out to this reported leaking. Machine is used in a dogs kennel so full of dog hairs and suchlike. Turned out the machine was overfilling and water was getting over the top of the drum. Pressure chamber seems clear but sealed onto tub so replaced pressure switch and machine now fills to correct level and doesn’t leak.
    However, the machine now doesn’t spin at the correct speed – probably about a third of what is normal on these machines. I did notice the gearbox was pretty rusty from the leaking (they had continued to use it while leaking for some time) – could this be the cause of it? I see very few of these machines, normally coupler replacement or inline fuse so a bit stumped but eager to learn :).
    #344152
    chezza
    Re: Whirlpool 3RGSC9400RL0 not spinning correctly
    I would have a look at this
    http://www.youtube.com/watch?v=tVc6SZ2DD4U
    #344153
    EFS
    Dog kennels rings a bell.
    I took two buckets full of dog hair out of one of these recently.
    Not spinning was the complaint and it was solid with matted hair.
    Drum out and clean then home for shower and change. 👿
    Clutch will also be worn out BTW.
    Steve
    #344154
    odom
    Cheers, much appreciated. Yes, every time I go there I bring a spare pair of old overalls to wear as everything get’s covered in dog hair 😕
    Will order the clutch and have a stab at it :).
