As above no spin or drive to tub , drive shaft from gear box is spinning but no action in tub.
Is this just a clutch failier, have never done more than change drive coupler on these before, so any advise on changing clutch would be a help.
Do they have a clutch or is it simply the coupling failed?….I have seen them where the one side of the coupling is split so it looks like everything is rotating but it doesn’t grip the gearbox shaft.
