Whirlpool 3RLEC8600SL1
  • #53806
    silverbroom
    This front loading commercial dryer requires a pulley wheel which connect seem to have.
    Any tips on fitting this, front or back approach (tumble dryer that is).
    thanks silverbroom
    #317309
    Re: Whirlpool 3RLEC8600SL1
    Is it the belt tensioning pulley? I think you’re best going in from front. Pull out lower section of front – held in by (rusted in place?) springy clips. Get the fan chamber front off and reach a hand round behind to the other end of the motor (power off 😆 ) Don’t ask me if there’s a uf there, I can’t remember. No, I think it works on a centrifugal switch, but take care. There you’ll find the motor pulley has a hexagonal end so you can get a spanner over it to hold it still (about 21mm IIRC) while you unscrew the plastic fan in the direction indicated by the arrow embossed in it’s edge. Once that’s done it should all be obvious.
    Mike.
    #317310
    silverbroom
    Thanks for that Mike, part on order and will let you know how I got on.
    silverbroom
    #317311
    silverbroom
    Spot on Mike but had to break the fan off, anyway job done so thanks again.
    silverbroom
