Whirlpool 3RLEQ8000KQ0 tumble dryer
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Whirlpool 3RLEQ8000KQ0 tumble dryer
  • This topic has 6 replies, 3 voices, and was last updated 6 years ago by AMS.
  • #97345
    AMS
    Probably a simple one for someone with more knowledge of these things….
    American style tumble dryer will not start. Press start button and the relay latches but no go. Door switch ok. Could a tripped thermal fuse cause this problem?
    Cheers,
    a lot of them have a hidden 6.3a fuse in the wiring harness. search the harness coming out of the timer and you might well find an inline fuse holder
    if it is a thermal fuse it will be the one on the exhaust. there are 2 stats on the exhaust pipe as it leaves the fan. the one with 2 connections is a thermal fuse
    looks like
    https://shop.ukwhitegoods.co.uk/c00313061-tumble-dryer-element-thermal-fuse
    AMS
    Thanks Dave. I did look for a fuse, but I think that’s only in the washing machines. Would need to be bigger than 6.3a in a tumble dryer I would have thought.
    #467141
    its only feeding the motor the elements are switched by the motor so they cant come on unless the motor is running
    clockworkone
    Broken belt micro switch.
    #467143
    AMS
    clockworkone wrote:Broken belt micro switch.
    Go to the top of the class Clockworkone, it was indeed a broken belt. Never knew it had microswitch to detect a broken belt. Thanks.
    Btw, can anyone confirm that 481935818142 is the correct belt?
    Cheers,
    Dave [h=1][/h]
    #467144
    cant be 100{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} but i would say 90{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} likely
    new number is C00313084
    Qualtex has stock but they close today for how long ? Who knows
