Whirlpool 3RLEQ8033sw1 Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Whirlpool 3RLEQ8033sw1 This topic has 4 replies, 3 voices, and was last updated 15 years ago by geoff1. Viewing 5 posts - 1 through 5 (of 5 total) Author Posts March 23, 2011 at 9:46 pm #61848 geoff1Participant Hi ❓ Can anyone advise why the duct stat with red dot does not even last a load before it goes o/c? (480112100395) I have cleaned all the pipes to ensure that they are not blocked or resticted. Just in case I have missed something many thanks Geoff March 24, 2011 at 1:03 pm #347853 electrofixModerator Re: Whirlpool 3RLEQ8033sw1 this dryer works on vacuum the motor causes a vacuum in the drum which pulls the air in over the element so you are lookin for 1 air flow problems which includes recirculation of the hot air 2 leaks in the drum seals if these seals leak cold air gets in but more important the air is bypassing the element causing it to overheat hope this helps Dave March 24, 2011 at 1:04 pm #347854 electrofixModerator Re: Whirlpool 3RLEQ8033sw1 ps you can reset stats by tapping them on the floor firmly Dave March 24, 2011 at 5:33 pm #347855 EFSParticipant Re: Whirlpool 3RLEQ8033sw1 electrofix wrote:ps you can reset stats by tapping them on the floor firmly Dave Works even better if you put it in a freezer first Steve March 25, 2011 at 4:37 am #347856 geoff1Participant Re: Whirlpool 3RLEQ8033sw1 Thank you very much for replies. Will go over the seals etc to see what is happening. Thank you for your tips on resetting these stats 😀 Geoff Author Posts Viewing 5 posts - 1 through 5 (of 5 total) You must be logged in to reply to this topic. Log In Username: Password: Keep me signed in Log In
