Re: Whirlpool 3RLSQ8033RW2
before removing clutch check the following
1 remove outer case ( support rear of machine against a wall or something )
2 short out safety switch on lid
3 set machine to spin and turn on
4 with a torch look at clutch on top of gearbox. if the clutch outer is turning then can only be clutch wear,oil contamination or stiff main drum
5 switch off machine and isolate check for oil around clutch area
all other checks need gaerbox out but it comes out in less than 10 mins
hope it helps
