Whirlpool 3XLER5435HQ-0 Tumble Drier,
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Whirlpool 3XLER5435HQ-0 Tumble Drier,
  • #32498
    RocketMan
    got one of theses WP driers on tomorrow. Done some work on some work on some of the other larger WP TDs before so I’m reasonably ok with them… it’s just been about 18 months since I’ve seen one… an not seen this particular one before. (I think PNC is 8570 950 0110 although customer couldn’t find it).
    On pre-diag customer says it hummms and the drum doesn’t turn.. pretty sure these aren’t cap start motors… I asked cusotmer to try and turn drum but said he couldn’t but didn’t use much force when trying.
    Any particular quirks on this model…
    Steve
    #235356
    MDE
    Possible dry motor bearing, have replaced a few motors for this.
    Mark.
    #235357
    RocketMan
    Re: Whirpool 3XLER5435HQ-0 Tumble Drier,
    Mark,
    Thanks for that… will definately have a check of that… GREAT help, not some thing that immediately struck me…
    I’ll let you know how I get ok.
    Thanks again
    Steve
    #235358
    RocketMan
    Didn’t get to this today but delayed until tomorrow or even Wednesday. TBC.
    What’s the best way to change the motor?? (if it is the motor)
    Obviously front off..no problems. The drum rests on 2 trollies or wheels I believe. Does the drum just lift off the wheels and out?? (After disconnecting belt from the pulley.) I know there’s no shaft at the rear of the drum.
    Any futher tips would be appreciated.
    Steve
    #235359
    realengineer
    remove top
    remove front
    remove belt from shaft
    remove drum
    remove fan
    remove clips
    remove motor
    ring whirlpool
    and a friendly engineer makes all f.o right again for you
    not realy hardest thing is removing fan
    make sure u got motor and fan b4 u start
    good luck
    jan de man
    belgium lost in the uk
    #235360
    MDE
    If i remember correctly the fan is a left hand thread.
    Mark.
    #235361
    realengineer
    Re: Whirlpool 3XLER5435HQ-0 Tumble Drier,
    sorrie i forgot to mension that 😀
    thanks for that
    #235362
    johnmac11
    If it is the motor quote for the fan as well. In a lot of cases the little buuger wont come off and the only way to remove it is to smash it with a hammmer.
    John
    #235363
    realengineer
    thanks i did say that before 😛 😆
    #235364
    RocketMan
    Hi to all who helped. You were all correct…it was partially seized bearings on the motor…
    johnmac11 wrote:If it is the motor quote for the fan as well. In a lot of cases the little buuger wont come off and the only way to remove it is to smash it with a hammmer.
    John
    I couln’t get that chuffing fan off and it needed a new one but enjoyed getting it off – had a smashing time !
    Thanks Steve
    #235365
    realengineer
    o thanks
    i did tell you to no thanks 😳 😕
    well great to know we helpt you out
    haha
