whirlpool 6 flashes
  • #52545
    naima
    hello,
    whirlpool dishwasher dwg 406 flashing six times – fill problem?. tried a few things following your helpful forum:
    – cleaned water level indicator in sump.
    – changed waterstop inlet pipe for simple non waterstop type as suspect limescale build up. No change – ran some white vinegar through original – now back on.
    – unplugged/replugged pcb connections on left side flow meter.
    Suspect inlet valve on machine?
    Any advice appreciated. Thanks
    sincerely
    mark 😀
    #312239
    Re: whirlpool 6 flashes
    If there is no water entering the machine at all, check fill valve. A test meter reading should show in the order of 3.5kOhms. Also the obvious – tap open, fill hose not trapped or kinked over, filter into valve not choked.
    If there is water entering the machine, the flow meter in the water matrix is a prime suspect. You may hit lucky and find that the connections have oxidised. A good clean and a pinch of the connectors may do the trick – otherwise, you’re looking at replacing the matrix as an assembly. L/h side panel off to see what’s going on.
    Power off for anything other than observation.
    naima
    ok thanks.
    Works now, not sure how I got there but I know why – your advice.
    Great site.
