Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Whirlpool 6th Sense ADP8940
- This topic has 5 replies, 3 voices, and was last updated 21 years, 7 months ago by
woz.
August 18, 2004 at 11:41 am #6055
woz
ParticipantHi Chaps
I have this dishwasher and all its doing is draining i checked the over flow and all seems ok.
Is there a test program for this model or a reset sequence as i’ve never even seen one of these before
Thanks in advance
Woz
August 18, 2004 at 1:23 pm #115351Dave_Conway
ParticipantRe: Whirlpool 6th Sense ADP8940
Woz, double check the model number, it doesn’t exist. I even tried just ADP89** (wildcard) still nothing.
August 19, 2004 at 5:24 pm #115352DentedPorsche
Nearest I can find to this is the ADP8942 which is a french version.
From the description of the fault it sounds as though there’s water in the base activating the floater switch. Switch the power off, tilt the machine backward slightly and see if any water drains out of the base. If it does then one of three things can be the cause, a blockage forcing water into the base, a leak or too much foam (is your rinse aid setting correct? has rinse aid been spilled prior to the fault?)
If I’m right you should also be getting an F2 error code.
Hope this helps.August 20, 2004 at 7:35 am #115353woz
Thanks DP
There’s definately no water in the base i’ve already checked the float switch and all seems ok.
Also there is no error codes it justs looks as though the DW is going to start but all it does is start the drain pump lasts about 5 minutes the stops and just sits there like a lemon. If you stop the programme it just goes back to draining.
Technical at whirlpool are supposed to be getting back to me as they don’t recognise it either.
Cheers
Woz
August 20, 2004 at 7:49 am #115354DentedPorsche
Ok, this isn’t conclusive but from what I’m reading my guess has to be either the fill hose has been crushed and has collapsed cutting the water supply, the inlet valve isn’t opening or the module itself is faulty.
With the first two you should eventually get an error code. With a faulty module you don’t normally get an error code as it cannot check itself.
Hope this is of some help to you.August 20, 2004 at 11:03 am #115355woz
Thanks agian DP
I think i’ll just tell him to scrap it, he didn’t pay for it in the first place
I can’t be A**ed with it anymore
Cheers
Woz
