Whirlpool 6th sense Washing M/C. AWO 7661
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Whirlpool 6th sense Washing M/C. AWO 7661
  • #28451
    joe2000
    Washing machine fills then ‘Water tap closed’ LED comes on
    Nothing else happens
    #218410
    Re: Whirlpool 6th sense Washing M/C. AWO 7661
    It means rise in water level not detected in the time allowed. You say it fills, so presumably there is a problem with the water level control system – air bell choked, pressure tube holed/kinked/disconnected or switch failure. Machine syphoning could give same result.
    Power off before removing any panel.
    joe2000
    Thanks for input, pressure vessel dirty, lime and sludge.
    cheers.
