Whirlpool 853703610600
  • #37261
    DentedPorsche
    Hiyas,
    I’ve got a replacement pressure switch to fit but it’s different to the original. No documentation with the pressure switch and now I find no Technical Bulletins online (that I can find).
    Does anyone (John Mac?) have the conversion details for this, or have I been supplied the wrong thing? Part number online matches (481927128993).
    Brian
    #254161
    Re: Whirlpool 853703610600
    Blimey Brian, I thought you were the font of all Whirlpool wisdom 😉 Leigh sends his regards by the way.
    #254162
    johnmac11
    Hi Brian,
    Part number is correct and there are no service bulletins that I can see.I have saw a few pressostats that have changed from the round shape to a a new slimline oval shape but the connections are the same.
    John
    #254163
    DentedPorsche
    Hi Phil, I wish mate. Regards to Leigh when you see him.
    John, thanks for that. The numbering on the switch is different but I’m pretty sure I’ve got it ok.
    Now I’m stuck with a fault I’ve not come across before.
    Machine goes through the wash ok, empties, refills for the rinse and………. just stops. The timer and now the pressure switch have been replaced but same fault as before replacement.
    Any ideas?
    Brian
    #254164
    johnmac11
    Possible lid lock, I have saw a few where either the lock is either knackered or the moulding it sits in drops slightly. If this happens it will allow the machine to go through the program and jam just before the spin as the lid has not locked.
    easy way to tell is to wait until it stops and see if you can lift the lid, if you can reach in and under the lock and pull upwards, you should feel the cover snapping back into place, the lid will then lock and your done.
    John
    #254165
    DentedPorsche
    Thanks John, I’ll check that out and let you know how it goes.
    Brian
