Whirlpool AA 1000 Integrated Washer(AWM 049) drum not rotating during cycle, it was making terrible banging noises now its not rotating during any cycle. Any Help Please
Re: Whirlpool AA 1000 Integrated Washer drum not rotating
A couple of possibilities. The noise may have been collapsed drum bearings which has then caused the drum pulley to wobble and throw off the belt. Another thing to check for is loose concrete counterweight blocks which may have damaged the motor wiring. These faults should be obvious once you see inside the machine but then the next thing to check is the motor brushes.
