Whirlpool ADG 290 dishwasher Fisher Paykel (twin draw DW)
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Whirlpool ADG 290 dishwasher Fisher Paykel (twin draw DW)
  • This topic has 2 replies, 3 voices, and was last updated 18 years ago by M1.
  • #35298
    M1
    Can anyone help with this DW Fault.
    It won’t let you select any programs just stays on first progrwm pots/pan wash & starts pumping, after a few seconds the green light goes out and the red one comes on (these are on the front of the machine) The DW does this on both draws top & bottom.
    Is there a anti-flood mechanism on these DW is it stuck in this mode because it has detected a leak ??
    Sorry to sound dumb but never worked on one of these before 😯
    Are they easy to repair & get spares ??
    #245924
    lerch
    Re: Whirlpool ADG 290 dishwasher Fisher Paykel (twin draw DW
    Take out the bottom draw as the sensor from memory is at the back left hand side. You only require a small amount of water to activate the anti-flood about a tea spoon very sensitive.
    Dry the area and re-try this normally happens when delivered as they are water tested before and if not kept upright water gets into base. 😀
    #245925
    jwd_73
    as above sounds like an F1.
    You have to make sure the area around and under the mains filter board is bone dry, and that the board has no corrosion/damage.
    Once the board is out for inspection you can push a screwdriver under the board chassis gently and it will lift from the base so you can get some kitchen roll underneath .
    Worth checking
    1 Abnormal load ie something obstructing the lid closing properly.
    2 Lid motors
    3 Link support broken causing 1
    4 Leak from inlet pipe/waste pipe mice like the waste pipe
    5 air flap in spray arm
    6 Impellor on motor loose
    I love them and I get to work on them every day 🙂
