Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › Whirlpool ADG 332 S WH Dishwasher Light Flashes 6 times.
- This topic has 5 replies, 3 voices, and was last updated 16 years, 10 months ago by
strapkass.
May 20, 2009 at 3:31 pm #45863
strapkass
ParticipantDoes anybody have any idea what fault six blinks on the green power light inicate?
ADG 332 S WH – fills ok and then the green light flashes six times, pauses and repeats continuously. Drains ok when reset, but will not progress beyond the refill stage…
thanks
Adam
May 20, 2009 at 8:25 pm #287405spimps
ParticipantRe: Whirlpool ADG 332 S WH Dishwasher Light Flashes 6 times.
6flashes=
Water inlet problem,is the water switched on,filter blocked on supply connection onto machine or faulty inlet valve.
BGMay 21, 2009 at 12:48 pm #287406strapkass
Thanks for the advice although I am unsure if what you say is the complete problem since I left the machine disconnected from the mains supply overnight in the hope of resetting the memory and tried again the following day…The machine appeared to go through a complete wash cycle but unfortunately at the end of the cycle, reverted to the six flashes…The wash cycle was also cold instead of hot…if that has any further bearing on the problem..
May 21, 2009 at 1:29 pm #287407strapkass
I have removed the supply to the machine and the gauze filter appears clean although now when I reconnect, the machine gives three flashes and not six and neither does it fill up anymore…the water supply is switched on and the pump does drain any water that is in the sump.
May 22, 2009 at 6:53 am #287408mogy
Let me start by explaining that I am no engineer. I only have information gained from this forum. I recently posted a question about a whirlpool DW (different model but Whirlpool) Mine was flashes 3 times as you now describe. I was told that it was the heating system for mine and to check all the connections in case I dislodged one when replacing the NTC. If you get no other responses then I guess you could try the same. I’ve not been able to check mine yet.
Maybe someone else reading could at least say if the codes are standard amongst the same brands.
Sorry to not be able to help more.May 22, 2009 at 11:22 am #287409strapkass
After fiddling around with the settings on my machine it now does the following: If I disconnect the power over night, it will drain, fill, do one cold wash cycle and then revert to 3 flashes on the main push button switch. It then will not accept any instruction via the rotary knob unless disconnected from the main power supply overnight and will then repeat the whole process and so on.
