Whirlpool ADG 332S
  • #26340
    ChrisR
    Hi guys.
    I`m getting 7 flashes after the machine has been working perfectly for about 20/25 minutes.
    In error codes it says flow meter failure,I`m not familiar with this model so what is the flow meter and where is it.
    Cheers.
    aqualectric
    Re: Whirlpool ADG 332S
    Had this very problem a couple of weeks ago and it threw me as well. The flow meter is situated behind the left side body panel at the bottom of the airbox. It meters incoming water flow rates. :hmm:
    First of all, pull off the plug and clean the edge connector and refit. If the F7 returns, replacement of the complete airbox is the only answer.
    Hope that helps,
    Steve.
    #209757
    ChrisR
    Cheers Steve. Very helpfull 😀 .
