Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › Whirlpool ADG 450 fault
- This topic has 10 replies, 2 voices, and was last updated 8 years, 9 months ago by
scotland.
June 23, 2017 at 1:17 pm #91509
scotland
ParticipantI have the above model dishwasher which no longer runs a full cycle. It turns on, waits a bit and then starts this on off pumping cycle which repeats.
I’ve taken the side panel off. Here’s a video -https://youtube.com/watch?v=uRnVKPexbQ8
I’ve read about faults with whirlpool flow meters. Could this be the fault here or something else? Any parts I should check?
Many thanks for any advice.
June 23, 2017 at 7:51 pm #448365electrofix
ModeratorRe: Whirlpool ADG 450 fault
this looks a timer problem
this model appears in at least 2 types think yours is Smeg built
need the 12NC number to confirm also you model number may not be completeDave
June 23, 2017 at 8:02 pm #448366scotland
ParticipantRe: Whirlpool ADG 450 fault
Thanks Dave. Will check that later and report back.
June 23, 2017 at 10:35 pm #448367scotland
12NC is 851115115911. Model number ADG 450-3. Type(?) 12155
June 23, 2017 at 11:47 pm #448368electrofix
yes found it board part no 4812 905 08531
only 2 problems
1 I cant promise I am right
2 they don’t mention it but some timers have to be programmedlong shot
take out the timer, open the timer box and post good pictures of both sides of the board
June 24, 2017 at 9:43 am #448369scotland
Thanks again Dave. Can you confirm the location of the timer and I’ll get these photos?
June 24, 2017 at 11:40 am #448370electrofix
timer is in the door under the buttons
June 25, 2017 at 8:42 pm #448371scotland
ParticipantJune 25, 2017 at 9:20 pm #448372electrofix
As I say this is a long shot but judging by the fault your in with a chance
see your picture below. item with an arrow feeds the board with power. change it and see what happens, if you feel like soldering
http://cpc.farnell.com/epcos/b32924c315 … dp/CA07127
the only thing I don’t know is the distance between the leads on yours. the replacement is 27.5mm
DaveJune 25, 2017 at 10:48 pm #448373scotland
Pleased you’ve come back with a suggestion like this – was hoping you might! I’ve checked the pitch of the existing capacitor and it is also 27.5mm so I’ll go ahead and order that and give it a go. If I can fix this for a quid that would be great. Will report back in due course (going on holiday soon so may be after that). Thanks
August 18, 2017 at 1:23 am #448374scotland
Just to give an update which is that this worked perfectly. Thanks Dave!
