Whirlpool ADG 550 door spring problem
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Whirlpool ADG 550 door spring problem
  • #95296
    WhirlpoolNovice
    I purchased dishwasher door cables (1881050100) to replace broken ones, but on opening up the side of my dishwasher I have no idea how to hook the springs that attach to the cables back in place. The spring has a closed loop at one side and an open loop at the other. The closed loop side is the side I’m struggling to find anywhere to attach it to. Any help would be greatly appreciated. Thanks.
    #459951
    WhirlpoolNovice
    Yes. How do you attach the spring to it? I can’t get the closed end to stretch to get it onto this (assuming it’s supposed to clip onto the hole in that part). Thanks
    #459953
    will go on somehow
    from what I remember its just a “U” shaped loop but its open at one end so you can prise it up to attach it
    WhirlpoolNovice
    I was worried about doing that in case I damaged it, but glad to know that’s all it takes. Thanks so much for your help.
    #459955
    you wont damage it. its a spring under a lot of tension so a bit of prising by you is not going to do anything
