Whirlpool ADG 6340AV Flashes
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Whirlpool ADG 6340AV Flashes
  • #46150
    Latham63
    Programme starts,drains then starts to fill,stopping and starting in short consistent bursts. Eventually machine floods.
    Simultaneously the prog light and start light flash together.
    This appears to be an electrical control fault.I suspect either the main pcb at base of door or small square pcb on facia.
    Seems to rythmic to be a pressure fault?
    Any clues??
    #288396
    suedehead1
    Re: Whirlpool ADG 6340AV Flashes
    from what i have gathered the lights should flash a certain number of faults then give a pause the number of flashes is the fault code but it sounds like a flow meter or pressure switch fault.
    try search facilty and you should get some pointers.
    #288397
    Pcb is corrupted,
