whirlpool adg 642-not heating and gets stuck on cycle
Home Forums Public Support Forums Help And Support Dishwasher Help Forum whirlpool adg 642-not heating and gets stuck on cycle
  • #35191
    tim76
    My dishwasher had an intermittent fault of getting stuck on a cycle-it would run all day, then it suddenly stopped heating aswell…any ideas? There is only one power led on the machine and it doesn’t flash-I’ve done a visual check of the wiring and can’t see any breaks. Any help appreciated. Thanks
    #245463
    Re: whirlpool adg 642-not heating and gets stuck on cycle
    16 versions of this appliance – please post up the 12nc number – the one that starts with 8.
    tim76
    The number is: 8542 7691 5710
    Thanks.
    #245465
    This machine has an electro-mechanical timer, so the posts relating to flashing lights do not apply. These later machines were not very prone to loom breakages, so your suspects are the thermostat, the heater if it has now stopped heating, or the programme timer; which could give both faults.
    No easy solution other than to get the test meter out and check the components – if they meter out correctly, it has to be the programme timer. It’s expensive, so you need to get it right!
    Power off before going inside, please.
