My Whirlpool ADG 7460 has the common flow meter problem (six flashes). I cleaned the contacts on the sensor as perscribed in other threads – it seemed to work for a couple of weeks but now it has returned.
On closer inspection the reed relay glass case had fractured so I replaced it with another (but slightly bigger) reed relay from Maplins as they didn’t have the same size available. But I still have the problem. I’ll see if I can get the right size reed relay, but if that doesn’t work I may decide to replace the whole flow chamber.
So, does anyone know how do you replace the flow chamber?
