whirlpool adg 7540/1
  • #28729
    LittleMan
    i can start this machine on any program and it will drain for 5 min then beeps and flashes, and it dosenot have a float switch.
    can any one help
    Les 😕
    #219816
    Re: whirlpool adg 7540/1
    Count the flashes.
    LittleMan
    Hi It flashes constantly does not stop
    can you help
    Les
    #219818
    senseib
    In my experience with whirlpool d/w’s if the fault shows up quickly it is usually the NTC feeler – especially when it flashes continously.
    Hope this helps.
    Brian
    #219819
    Galway
    hi also check the diaphram switch in the sump it could be punctured !
    #219820
    senseib
    If not the thermister check the switch diaphragm in the sump, this often gets clogged-up. Often just removing rinsing out & refitting does the trick. I find these the two most common faults on Whirlpool dishwashers, with the latter being the most common.
    Brian.
    #219821
    LittleMan
    can you tell me the location of NTC feeler and what it is
    Thanks Les 😳
    #219822
    NTC is the thermistor sticking up like a finger through the base of the sump moulding. It should give a reading in kOhms. Even if it does, it can still not work…… To its right is the black grid of the water level sensor. Both a twist fit and can be removed from underneath.
    LittleMan
    Thanks for your help have rebooked call for monday.
    Thanks again
    Les
