Whirlpool ADG 7540 – Rattling Noise From Below
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Whirlpool ADG 7540 – Rattling Noise From Below
  • #62025
    I posted this on the end of an old similar thread but got no response, so hoping the more accurate subject will prompt a response.
    My dishwasher is a Whirlpool ADG 7540. Towards the end of the cycle there’s a rattling noise from below, although it does seem to complete okay. At first I described it as a stutter and searching for that lead me to believe that it might have a dodgy askoll pump, but after removing the front plate and watching it in action I’m not sure.
    The right-angled rubber hose and the heater are moving around quite a bit with the rattling noise. It looks to me like something is stuck in there. I’ve uploaded a video shot underneath to youtube:
    http://www.youtube.com/watch?v=sFoBlIfWpsc
    As per the previous post there is a fine grey oily residue on the plastic parts inside – something I hadn’t taken too much notice of.
    I’m also unsure who to remove the rubber hose clips to get a look.
    Found a good image of the underside parts here:
    http://i2.photobucket.com/albums/y2/Pen … rWplDW.jpg
    Any help appreciated. 😕
    #348430
    Re: Whirlpool ADG 7540 – Rattling Noise From Below
    Sounds like a bit of glass or something has found its way in there. But it does also look like the Askoll pump.
    The clips on those are quite special, so much so that we sell them here as getting some to fit is often a nightmare.
    But to find out you’ve no option but to strip it and see what the issue is.
    HTH
    Thanks for the response.
    So the clips on it are “use once clips” and to get them off I just have to break them? And then fit new ones to when I put it back together?
    #348432
    stuckinstandby wrote:So the clips on it are “use once clips” and to get them off I just have to break them? And then fit new ones to when I put it back together?
    Just wondering if anyone has any thoughts about getting the existing “clips” off? 😕
    #348433
    Applianceman2010
    I usually put a flat had screw driver into the join and give it a twist. either that or a pair of side cutters and grab th join and twist 😉 . Also ken the link for the clips didn’t work for me…..
    #348434
    Cheers, so just break them off and replace when re-fitting?
    #348435
    Applianceman2010
    Yup, just be careful not to damage the rubber hose which it clamps and.you will be fine.Also don’t be too shocked if you don’t find anything in there as the impellours do go on these dw’s but by the look of the you tube clip it does look and sound like something is in there. Hth DJ 😀
    #348436
    johnmac11
    Applianceman2010 wrote:. Also ken the link for the clips didn’t work for me…..
    Link now repaired
    John
