Re: Whirlpool ADG 7550
Thanks for the quick replies,
John,
I Have already had the problem with the pipes jumping out, couple of small cable ties sorted that one out !
kwatt,
Do you think that the motor is running too slow ?
When I open door quickly and look in I just catch the jets tailing off from the bottom sprayer. If I remove the bottom sprayer I can just see about 2″ high jet of water.
I would have thought the blast of water would go higher ?
This is why I thought the pump was on the way out, but if it is not running fast enough – same problem .
Is there any way of checking the motor speed ?
