Whirlpool ADG 7550 not washing – filling
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Whirlpool ADG 7550 not washing – filling
  • #34088
    mike08
    I have a problem with the above model dishwasher which just started last night. I tried a couple of washes and the tablet dropped out but never dissolved and there is a sound from the dishwasher which I can only describe as a chattering sound from the rear.
    I have pulled out the dishwasher and since finding the forum here, I have tried a few different washes etc but I dont seem to get error codes.
    It seems like the dishwasher is getting a slight bit of water but nothing much. If I open it during a cycle, it will have a small bit on the bottom (see picture) but thats about it.
    I assume my water valve is either gone or stuck?? Any help on how to diagnose/fix the problem would be appreciated 😆
    #241161
    mike08
    Small update
    Kept latch held in and opened the dishwasher on first soak setting and there is water coming through the bottom spray arm but very very slowly. Its not under any pressure. Seems like just a gravity feed.
    I assume this is a pump issue then? The drain pump seems to be running fine but the filling pump doesnt seem to be working
    Does the same motor/pump do both purposes? To access the pump on this machine, where do I open it up?
    #241162
    Re: Whirlpool ADG 7550 not washing – filling
    Consider this:
    http://www.ukwhitegoods.co.uk/modules.p … ge&pid=159
    mike08
    Thanks for the reply
    How do I get access to it on this machine?
    Also, are there 2 pumps? One for water and one for waste?
    #241164
    Machine out, towels down. Lay machine on left side and undo lower cover to reveal everything. Power off, of course and beware of the edges of any panel – you can shave with them.
    There are inded two separate pumps. The drain pump rarely gives any trouble unless you physically block it.
    mike08
    Great thanks
    Will attack it tomorrow and post back
    As for the edges, you’re dead right there!! I did a spot of “shaving” already today! 🙂
    #241166
    mike08
    Penguin45 wrote:Consider this:
    Bit late coming back!!! 😀 😀
    Anyway, you were 100{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} correct!! Ended up getting a new pump and its flying again
