Hi have a Whirlpool ADG 7560 dishwasher, it starts the cycle then pumps out for 10/15 seconds then stops and bleeps 4 times ( 3 short 1 long ) I have taken the machine out so I can check that water does come out and there is not a blockage in the waste pipes, Ive sucked water out through the waste pipe.This has happened a few times before but after turning the machine off and starting the cycle a few times it sorts it’s self out ( but not this time ) I have run the test mode until lit bleeps continually and checked the start light which flashes 5 times, the pump does work for around 15 seconds before the dreaded bleeps !
Any advise will be greatly appropriated.
Lawrence
