My whirlpool adg 7566 seems to finish its cycle ok but then gets stuck in beeping and flashing 4 times. The dishes look clean, but may be slightly wetter than before.
Other posts about the 4-times-flash point at a failing drainage, but there is no water left in the bottom of the machine.
I tried an empty cycle which ran fine, I heard the drying phase run and it ended without error code. Still when I run it full, it ends with the error-code 100{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} of the times.
Suggestions would be greatly appreciated.
thanks, Romke
