whirlpool ADG 957
  • #24808
    madden1
    Appreciate any advice that could help get this bugger working again:
    whirlpool ADG 957
    The two buttons at the far right end of the door don’t seem to be responding, The machine won’t start a cycle, the temperature of wash is lit up but I cannot select another temperature as the button doesn’t seem to be responding.
    Cheers
    #203373
    Re: whirlpool ADG 957
    User board slipped on mountings so buttons no longer contact – had that one once. Wiring problems between control panel and computer. Computer may have died.
    Complex machine with expensive components – I’d recommend some pro help to sort this one.
    Power off if you are going to investigate,
    madden1
    Cheers Penguin45,
    Sounds like you’ve hit the nail on the head, I’ve got a mate who is an electrician and owes me one, would he be pro enough or should I contact a specialist engineer?
    Good man,
    Madden1
    #203375
    Best option may be to use the link below and find a local UKW approved engineer in your area. It’s a bit of a specialised area.
    Good luck,
