WHIRLPOOL ADG 957
Viewing 15 posts - 1 through 15 (of 17 total)
  • #28563
    machineman
    Yet another d/w, switch on ,m/c selects rinse, all works ok, wait for prog to end and try and select main wash but it wont move off rinse. any help would be appreciated.m
    #218908
    machineman
    heeeeelp.m
    #218909
    clivejameson
    Re: WHIRLPOOL ADG 957
    What’s the Pnc number?
    #218910
    realengineer
    keep start button pressed for 7 sec
    try to select another program
    check for water in base if not replace timer
    #218911
    machineman
    854295715410.m
    #218912
    funkyboogy
    most probs ive had with these is
    1st t.mister @ sump, mostly give probs on heat…ie m/c runs for about 20 mins then aborts prog… (doesnt fit with your prob)
    2nd pressure sensor @ sump, gets stuck with grease etc… half turn takes it out, give it a good clean @ sink…most times ive had to replace this part??
    ally
    #218913
    clivejameson
    Does it come up with a fault code (start light flashing) and if so how many flashes?
    #218914
    machineman
    no fault code, once m/c has finished prewash switch off try to select another prog ,but wont budge off prewash.m
    #218915
    clivejameson
    Sounds very much like the pcb if it won’t program but doesn’t show a fault code. Worth checking the usual suspects first though like the NTC and leaks etc?
    You could always wing the pcb to EMW?
    #218916
    machineman
    cheers guys.m
    #218917
    realengineer
    controller i would say
    or pressure switch
    go for it
    #218918
    EFS
    Have any of your mates got a Whirlpool SAM module they would let you borrow?
    You can read faults & re-program the eeprom with it and sometimes this is all that it needs.
    Failing that you could buy one from Connect (order ref 5045170805081).
    You only need to save the cost of a couple of modules and it’s paid for itself 😉
    Needs updating now and then so you need a friendly Whirlpool agent to put new model codes in once a year or so.
    Steve
    #218919
    realengineer
    unless you are a whirlpool agent You can get a SAM
    I think 😕
    #218920
    EFS
    Connect have a order ref for it so why not give it a shot?
    Steve
    #218921
    realengineer
    I might like to buy one myself for my own use
    i have one from work but u never know as in the future u might have
    to program every single board.
    i know servis and hotpoint is doing the same
    keep work in own camp
    if anyone can tell me connect contact details
