Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › WHIRLPOOL ADG 957
- This topic has 16 replies, 6 voices, and was last updated 18 years, 9 months ago by
machineman.
June 28, 2007 at 5:27 pm #28563
machineman
ParticipantYet another d/w, switch on ,m/c selects rinse, all works ok, wait for prog to end and try and select main wash but it wont move off rinse. any help would be appreciated.m
July 3, 2007 at 7:33 am #218908machineman
Participantheeeeelp.m
July 3, 2007 at 7:46 am #218909clivejameson
ParticipantRe: WHIRLPOOL ADG 957
What’s the Pnc number?
July 3, 2007 at 7:51 am #218910realengineer
keep start button pressed for 7 sec
try to select another program
check for water in base if not replace timer
July 3, 2007 at 7:51 am #218911machineman
Participant854295715410.m
July 3, 2007 at 7:57 am #218912funkyboogy
most probs ive had with these is
1st t.mister @ sump, mostly give probs on heat…ie m/c runs for about 20 mins then aborts prog… (doesnt fit with your prob)
2nd pressure sensor @ sump, gets stuck with grease etc… half turn takes it out, give it a good clean @ sink…most times ive had to replace this part??
ally
July 3, 2007 at 7:57 am #218913clivejameson
Does it come up with a fault code (start light flashing) and if so how many flashes?
July 3, 2007 at 8:30 am #218914machineman
Participantno fault code, once m/c has finished prewash switch off try to select another prog ,but wont budge off prewash.m
July 3, 2007 at 8:45 am #218915clivejameson
Sounds very much like the pcb if it won’t program but doesn’t show a fault code. Worth checking the usual suspects first though like the NTC and leaks etc?
You could always wing the pcb to EMW?July 3, 2007 at 8:54 am #218916machineman
Participantcheers guys.m
July 3, 2007 at 3:31 pm #218917realengineer
controller i would say
or pressure switch
go for it
July 3, 2007 at 7:25 pm #218918EFS
Have any of your mates got a Whirlpool SAM module they would let you borrow?
You can read faults & re-program the eeprom with it and sometimes this is all that it needs.
Failing that you could buy one from Connect (order ref 5045170805081).
You only need to save the cost of a couple of modules and it’s paid for itself 😉
Needs updating now and then so you need a friendly Whirlpool agent to put new model codes in once a year or so.Steve
July 3, 2007 at 7:43 pm #218919realengineer
unless you are a whirlpool agent You can get a SAM
I think 😕
July 3, 2007 at 7:49 pm #218920EFS
Connect have a order ref for it so why not give it a shot?
Steve
July 3, 2007 at 8:21 pm #218921realengineer
I might like to buy one myself for my own use
i have one from work but u never know as in the future u might have
to program every single board.i know servis and hotpoint is doing the same
keep work in own camp
if anyone can tell me connect contact details
