Whirlpool ADG 957
  • #33750
    clayside
    Have problem with above dishwasher 854295715410 ser no 33 0102 000455. Select any programme drain pump runs then as soon as pump stops it bleeps, start light flashes continous ( no pattern ) and rinse light is on ( left hand light ). Machine keeps like this till switched off. Customer says by turning on and off she can sometimes get it to work.any help appreciated. Clayside
    #239872
    clayside
    Re: Whirlpool ADG 957
    Can any Whirlpool engineers help please. Regards Clayside
    #239873
    DentedPorsche
    It’s an older style dolphin range machine.
    Every error shows as a continuous flashing start light.
    You have to put the machine into diagnostic mode to get the correct error code.
    If you’ve got the Sios disk the instructions are on there. If not I’ll see what I can find tomorrow.
    Brian
    #239874
    clayside
    Hi brian, Thanks for reply. I have no info at all on dishwasher so any help would be appreciated. Its built in and I don’t want to pull it out it not needed. Look foward to receiving info.Regards Clayside
    #239875
    DentedPorsche
    Hiya, If you pm me your email address I’ll send the information I have for this machine.
    Brian
    #239876
    robwash
    hi, this machine is too early for diagnostics. Every fault shows up the same. You need to check the WI (membrane switch in sump) can be cleaned but better replaced. If you have an ntc its not a bad idea to simply plug a new one into the control board at the bottom to see if it clears the fault. ntc fault will clear straight away. Other than that, check all the usual, pump, element etc. These older dolphin models can be hard to pinpoint the fault… good luck, cheers Rob
    #239877
    spanner51
    I had the same fault on an older built in Whirlpool D/W. It was the cold tap turned off. So I would check the tap and cold valve.
    #239878
    DentedPorsche
    I’ve already sent the built in diagnostics routine. I’ve got the routine for older Dolphin Range Dishwashers as a pdf. Anyone needs it, just ask.
    Brian
